What is this?
Hey everyone,
Just wondering what in the world this is, the copper or black round piece under the wires? I'm not super inclined when it comes to engines so sorry if its a dumb question. It seems to be leaking oil and getting crap all over my engine. Thanks, Jon
Gotta Love a Grand Am Sitting Pretty on some 18's!!!! http://www.kettering.edu is the #1 Mechanical Engineering school in the Country!!!!! Everyone give BIG props to the godfathers of GA automotive forums!! Big thanks goes out to XERO!! |
Re: What is this?
im not positive but i think that's your fuel pressure regulator... not sure why it would be leaking oil though... unless its leaking gas and mixing with the grime.
Re: What is this?
i dont think its the fuel pressure regulator. Im not sure what it is but it is right on the oil pan. Its pretty close to the oil filter too, are you sure that the filter just isnt leaking onto it?
Re: What is this?
Re: What is this?
thats somethin with ur evap, I do believe, connected to it is that tiny hose?
not a big issue but the leak can cause a vaccume leak, high/low rpm idle I think it has something to do with the exhaust/emmissions going back into the engine, could be exhaust build up w/ the oil/gas gunk that gets put out Do find exactly where it is leaking tho. make sure that theeee.... I forget what its called lol, VAC valve? make sure it's not clogged or dirty... if it is, use some seafoam and just spray the valve out if you're not up to buying a new for for less than $2 or something lol
04' Mazdaspeed Miata - GT2860 @ 10psi 99' GRAND AM SE V6H.O. 188whp - Sold ![]() ![]()
Re: What is this?
Thanks again, Jon
Re: What is this?
that red arrow is pointing to the fuel pressure regulator.
They can leak and the fuel often is blackish in color. Either an "O" ring or its just bad.
1999 Grand Am SS 3.4 OHV
Re: What is this?
omg...i didnt even see the red arrow. I was looking at the bronze/gold colored part by the oil filter...which explains why i thought it was there. nvm
Re: What is this?
'01 Pontiac Grand Am GT30R powered 2.4L quad 4 432hp 424tq
Re: What is this?
Current: 2012 Toyota Rav4 3.5L V6 AWD Current: 2018 Tesla Model 3 LR AWD + Accel Boost Past: 1999 Pontiac Grand Am SE (sold 2013) Past: 2007 Mazdaspeed 6 Grand Touring (sold 2016) Past: 2009 Subaru Legacy 2.5i Special Edition (sold 2019) |
Re: What is this?
80% of the Cars with gas in thier tank is probly black in color , either due to debrie in the tank and or the oxidation that occurs in the aluminum fuel lines. Plus it could be from the detrioration of the "O" rings them selves that cause the gas to discolor'. Also the fuel would be more appearently black when the tank is not fully emptied regularly. ![]() ... like I said, he needs a new FPR + "O" rings ![]() This can be confermed with a fuel pressure check, should be 41-47 psi w/ key on.
Re: What is this?
Thanks a lot everyone for your help. It's truley appreciated because on this college budget of mine... (wife budget as well ) I can't really afford to pay someone 10x the amount to fix something!
Re: What is this?
yea jon its pretty easy and straight forward.
Just remember to relieve the fuel pressure from the shrader vavle on the pass side(looks like a vavle stem on your wheel, just bigger). Just use plenty of old rags to catch the excess fuel. You can also pull the fuel pump fuse and run it dry, which I personaly dont like doing. A good wrench and its off, theres just one big nut. The "O" ring is inside that nut usually. I'll see if I can find a pic....
Re: What is this?
Re: What is this?
That's cool !
I'm still lookin for a pic......
