Old 06-12-2007, 07:09 PM
aaron600rr aaron600rr is offline
Temp sensor
The temp sensor for the gauge in the side of the head busted off and an easy out wont take it out what other options are there?
Old 06-13-2007, 02:20 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: Temp sensor
I personally would live without the guage, you could try drilling it out and re-thread it (try using a left hand bit first, it may catch and thread it out for you), but if you screw up you could end up having to replace the head.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 06-13-2007, 03:46 PM
2000CAYukon 2000CAYukon is offline
Re: Temp sensor
There will also be an unused hole on the other head in the same location with a plug in it. You could install a new sensor in the other head. Or course, you will need to add some wire but that is an option.
//2000CAYukon
Old 07-08-2007, 11:17 AM
Elbert Elbert is offline
Re: Temp sensor
Get the right type "socket" to remove the pipe plug in the RH head. I would only attempt to remove that plug as a last resort, becuase they generally are hell to get out.
How did the sending unit in the drivers side head "break off"? Is there no "nut" left on the sending unit in which to use a socket to remove? Generally you have reasonable access to the drivers side head. I would imagine there is a way to get it out.
If the truck is a TBI engine you don't have to many other options. You can atteempt to remove the pipe plug in the RH head, but I would avoid messing with that, especially with the engine in the truck.
