99 C1500 classic
My C1500 Ext. Cab is along the lines of the 98 and later. I hope I am in the right place.
I have a 5.7 in my truck. It is supposed to tow 7000#. I have a 2500+# Trailmanor RV. While trying to tow it through the Ozark portion of I55 in MO my truck started missing badly. I had already replaced (sort of) the cats, installed new Champion plugs and Duraspark wires. A check at an Autozone said I was having "MULTIPLE CYLINDER MISSFIRE". I changed the distribuater cap and rotor with no luck. Could I have a clogged fuel filter or weak fuel pump that is starving the engine or something else? Glenn in TN |
Re: 99 C1500 classic
Does it run bad at idle or just under load? If it runs ok at idle, it could be a fuel flow/pressure issue. Get a guage and hook it up to the test port and power brake it.
'04 Cavalier coupe M/T 2.2 Ecotec Supercharged 14 PSI boost, charge air cooler, 42# injectors Tuned with HP Tuners Poly engine/trans/control arm bushings Self built and self programmed progressive methanol injection system |
Get rid of the champion plugs and put AC plugs in it and maybe get some AC wires
2006 VW Jetta TDI Diesel (Super fuel mileage) 2004 Chevy 2500 6.0 Crew Cab 1993 Chevy K1500 5.7 (love this truck) |
