94 C1500 Whistling at Intake???
I have a 94 1500 with a new 4.3L and I keep hearing a whistling noise coming from around the intake manifold. I have looked into it and it only happens when I feather the accelerator lightly and quickly. When just idling, it does not do it. I first assumed it was a vacuum leak, but cant seem to locate any vacuum lines off or not plugged. Im hoping that someone else has had this problem and can help me out on a solution. Thanks all.
03 Chevy Trailblazer LT EXT 04 Silverado Z71 88 Fiero Formula V-6 82 Chevy Corvette 07 Dodge Caliber |
Re: 94 C1500 Whistling at Intake???
It is most likley a vacuum leak. Use a can of carb or brake cleaner with the motor running and spray around intake area and throttle body. Should hear a change in rpm's when you find it.
57 Chevy 210 65 Olds 442 Convertible (Another one sold) 75 GMC Vandura 3/4 Ton 1999 K2500 Old Body Style Suburban (Gone but not forgotten) 05 Dodge Ram 3500/5.9 Cummins 2012 Toyota FJ Cruiser |
TBI Base gasket was leaking. Used the can of carb cleaner and found it within 5 minutes. Replaced gasket and no more whistling. Thanks Stickman for the help.
Good job and thanks for posting back.
