Old 06-12-2007, 02:01 AM
bigdawgjr bigdawgjr is offline
1996 jimmy tranny filter
I just changed the tranny fluid and filterin my 1996 jimmy every thing was working ok before I changed it exceptrev sounded funny, anyway I changed it now theres no problems with rev. but when I put it in drive it seems to start out in like 2 or 3 gear , I have to put the peddle to the floor to start moving but once it gets going it fine , anybody have some suggestion
Old 06-12-2007, 02:13 AM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: 1996 jimmy tranny filter
4L60E?
If you get a check engine light (MIL or Malfunction Indicator Lamp), put a scanner on it and see what the DTC is.
If you get a P0758, drain the fluid and drop the pan. At the rear of the valve body are two solenoids that look similar. These are your 2-3 shift A and B solenoids. Check to make sure you didn't disconnect the wire by accident when you pulled the filter out. I did a fluid and filter change on a 4L60E last week and wound up doing exactly that, and didn't realize it until I put it together and tried to take it for a spin. What happens if one of those is disconnected is the transmission goes into 'safe mode' and will start out in 3rd gear, and set a P0758 DTC on the computer.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 06-12-2007, 09:36 AM
That is exacly whats happining , but I dont have a cheak engain light on, I did scannen it with an OBD2 reader, (I don't know how good those are) but it did read a code ether? are the two solenoids toward the front?
Old 06-12-2007, 12:50 PM
silicon212's Avatar
Confoundingly Lucid
The following picture was unceremoniously stolen from Blue Bowtie, resized and remarked for your viewing pleasure -
The arrows point to the two solenoids. In my case, I banged the connectors with the pan when I was maneuvering the pan past the exhaust crossover pipe.
Old 06-12-2007, 04:50 PM
that is awsome thankyou very much , thats was exactly what happened with mine, after taking the stupid pan off again and using you pic i figerued it out. thank-you very much
