Old 06-11-2007, 06:08 PM
ck19891500's Avatar
ck19891500 ck19891500 is offline
transmission
I have a 1989 k1500 350 5.7 automatic I am asking what is compatible with my transmission? I know its a 700r4 and they really suck but I still need the overdrive for all the highway driving I do. I am not looking to rebuild just want to replace. If someone close enough by has one let me know doesnt have to be rebuilt. You can email me at [email protected] but my question is what years and what vehicles can I change it with? I recently put in a 350 out of an 88 suburban with 30,000 miles on it. I found a 85 700r4 rebuilt from a suburban would that work?? Thanks for any help..
Old 06-11-2007, 06:18 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: transmission
Any non-electronic transmission from behind a GM V8 will work
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 06-11-2007, 08:34 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: transmission
The 700R4/4L60, when properly set up, are far from junk. With a good reaction sun shell, input drum/shaft and the requisite amount of 3/4 clutch plates, along with a Kevlar 2-4 band and a good strong input planetary pinion set, can handle up to 700 lb. ft. of torque - on par with a TH400. Avoid years before 1985 as these have TH2004R input shafts and torque converters (27 spline) and have some teething problems.
I would, however, suggest a transmission with a build date newer than May 1986. These have an auxiliary valve body in them whose job is to smooth the transition from neutral into drive/reverse.
Your only other overdrive option is a TH2004R, and while these are good in even big cars, I wouldn't use one in a truck.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 06-12-2007, 07:40 AM
bigcoconut bigcoconut is offline
Re: transmission
I have heard a lot of bad things about the 700R4 also, but I have had a 91 1/2 ton extra cab and I now own a 92 (I upgraded) step side. My experience with towing Boy Scout trailers all over Texas, Louisiana & Arkansas for the past 9 years is that the 700R4 is bullet proof. Keep the fluid clean and the temperature down and she will serve you well.
Up to 93 or 94 (can't remember which year) the 700R4 is the same as the 4L60, GM just changed the name. Beware of the 4L60E, she is not the same and won't graft into your truck.
"Yes I have a truck and No I won't help you move your stuff..."
2008 Kawasaki KLR650 2500mi (fairweather commuter)
1992 C1500 Silverado 235,000mi (daily, not so much anymore, driver)
1999 Venture 120,000mi (moms vacation bus)
1989 Dodge Ramcharger SOLD, Yee-Freak'in-Haw
Old 06-12-2007, 10:07 AM
ck19891500's Avatar
Re: transmission
Thanks for the help....
