Old 06-11-2007, 04:26 PM
mixedgrip mixedgrip is offline
Evaporative emission control malfuction
I am getting a P-0440 code on a 1999 Lumina LTZ 6 cyl 3.8L. The book says "evaporative emissions control system malfuction". Anyone have an idea of what to look for? Is there any likely-hood of a performance issue?
Thanks for your help.
Jim
Old 06-11-2007, 05:34 PM
jeffcoslacker's Avatar
jeffcoslacker jeffcoslacker is offline
Lactose the Intolerant
Re: Evaporative emission control malfuction
Check the gas cap and the hoses going to the canister in the left rear fender behind the wheel...
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
Old 06-19-2007, 07:57 PM
99luminaguy 99luminaguy is offline
Smile Re: Evaporative emission control malfuction
I recently posted a P0446 which is a small leak in the evaporation system. I first replaced the vacuum purge solenoid (on top of engine), then the gas cap and finally the vapor canister valve (behind left rear tire). The code disappeared after the vapor canister valve was replaced.
Old 06-19-2007, 08:16 PM
Thanks for the post. Right now my daughter hasn't had any more code issues. We checked the gas cap and canister but not the valve. If the code reapears I will check that as well.
