Old 06-11-2007, 04:20 PM
mr3000 mr3000 is offline
which spec(cali/fed)??
how would i find out which spec(cali/fed) my car is?
Old 06-11-2007, 05:10 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
Re: which spec(cali/fed)??
you have an NA, right? (non-turbo). if you have pre-cats (there would be one each, after the exhaust manifolds, but before the main cat).
for help, see the pic at the bottom of this page.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 06-11-2007, 05:17 PM
ok, ill take a look
