Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 06-11-2007, 04:04 PM
deezdrama deezdrama is offline
ignition switch- reason for tranny problems???
My 93 suburban started shifting hard into second a while back- Now it seems to slip in reverse and in first gear. Well ive been looking for a rebuilt tranny but now my ignition lock cylinder gets stuck when the car is on- You cant turn the truck off!!! I had to turn the key foward making the starter gear squeel just to get the key to turn off and get the key out.
Now does this sound like a bad tranny and a bad cylinder lock-
or-
Could the actuall ignition switch be going out and making my tranny act up??
UGH-- I just dont know where to start
Old 06-11-2007, 04:16 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: ignition switch- reason for tranny problems???
or-
Sounds like two seperate problems, one being much more expensive than the other. We don't do transmissions at my shop, and it's been a while since I took the class, but I think first and reverse share a band or clutch. Will probably need a complete rebuild... take it to a tranny shop to be sure.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
