Old 06-11-2007, 03:21 PM
HoustonHelix HoustonHelix is offline
MISFIRE - help, please!
Scanner indicates a "Misfire on Cyl #6".
I tried to isolate the problem by switching with Cyl#5 the sparkplug, then sparkplug wire, then injector. Each time I would do a switch, I would reset the Engine Service light, wait for it to come on, then do a reading. Each time the light would come on it would indicate the same message not showing the problem jumping to Cyl #5.
Since I have determined that the plug, wire, and injector is good in Cyl #6, yet continue to get a misfire, could someone advice on what I else I need to check? I read somewhere that there might be a "vacuum leak". How exactly is that checked?
Old 06-11-2007, 03:41 PM
youngvr4's Avatar
youngvr4 youngvr4 is offline
STREET RACING GURU
Re: MISFIRE - help, please!
i'm trying to understand you, so you switched them to cyl 5 and its still missfires on cyl 6?
Old 06-11-2007, 04:49 PM
AutostradaVR4 AutostradaVR4 is offline
^thats what im taking it as...
maybe the coil?
how's the compression?
Formerly BlinkRA182
--VR-4-- --09 Lancer RALLIART-- --Me--
