Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon > 1st Gen 95-99
Old 06-11-2007, 02:57 PM
neonracer9787 neonracer9787 is offline
Exclamation need help
I have a 97 neon sohc. And I keep getting a code that say that I have a misfire on cyl 3. I just put new plugs and wires on it because I thought that was what it was but no. but it not an all the time problem it comes and goes. When I reset the comp it goes away for a while then it might come back right away or it may take a few days of driving. I have tried to unplug the comp and re plug it in but still same thing. One day when it was acting up I pull the 3rd cyl plug and it was still dry and good. So I figured I would check the fuel injectors and when it was running rough it was the same as if you cut the fuel from another injector. i then switched the injectors around to see if it was a bad injector but nothing. I also checked the wires that run from the injectors, form what I can see they are good. so now I am out of ideas, is there anyone out there who has had the same problem or something like it??
Thanks,
Neonracer9787
Old 06-12-2007, 01:30 PM
das2123 das2123 is offline
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
Re: need help
Have you checked the leads on the coil pack?
2003 Dodge SRT-4
Old 06-12-2007, 02:41 PM
Re: need help
all the wires that i can see look good. its hard to see it completely cause it is hidden in the wireing harness
Old 06-14-2007, 07:49 AM
Re: need help
No, not the wires...the LEADS on the coil pack. Where the spark plug wire connects to.
2003 Dodge SRT-4
Old 06-14-2007, 11:00 AM
Re: need help
ya i checked them already they are good.
Old 06-14-2007, 11:29 AM
Re: need help
Did you reset the PCM when you were done?
2003 Dodge SRT-4
Old 06-15-2007, 11:09 AM
Re: need help
ya that still didnt work but thanks for trying
