Old 06-11-2007, 09:16 AM
cta2885 cta2885 is offline
why would this keep happening?
1991 Cavalier 2.2l 221k miles
The plunger on my starter keeps breaking. Which is making the bendix keep bouncing and grinding against my flywheel. Over the weekend i went and had my flywheel checked to make sure it wasnt that. but there isnt anyone that can give me a straight forward answer. The next starter i put on will be the 4th in less than 4 months. Please any suggestions will help
Old 06-11-2007, 11:53 AM
Re: why would this keep happening?
ive heard many different things. Wiring? Flywheel warped? Heat? Shiming? im seriously because of this! SOMEONE PLEASE HELP!
Old 06-11-2007, 12:02 PM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
How did the 'first' starter go out, same way, or this problem started occuring after that replacement?
Old 06-11-2007, 12:05 PM
same exact way. i had my flywheel checked and its all correct
Old 06-11-2007, 12:06 PM
wrightz28's Avatar
Manual or auto trans?
Old 06-11-2007, 12:07 PM
auto
Old 06-11-2007, 12:21 PM
wrightz28's Avatar
When you replace the starters, are you reusing the same solenoid on each one?
Old 06-11-2007, 12:23 PM
no, its a whole new starter unit in one!
Old 06-11-2007, 12:29 PM
wrightz28's Avatar
Well darn, there went that idea.
If the problem started (no pun) out of the blue requiring the original replacment, it can't be a shimming issue. No repairs were done recently prior to this problem?
Something must have moved out of proper alignment. Either the crankshaft or the converter in put shaft. A real far fetch all though not impossible, a loose bellhousing.
Old 06-11-2007, 08:01 PM
Yeah thats why i cant figure out why. I was told i could have a cracked flywheel, but i also thought that if i had a cracked flywheel i would know for sure with the noise it would make. OR i have a backfire when i start my car. But when i start it, there is no backfire. So im totally lost?
Old 06-12-2007, 12:03 AM
Blue Bowtie's Avatar
Registered Offender
If the trans is a 1254C/3T40, and the TC thrust/pump bushing is worn enough after that kind of mileage, the converter could be pushing forward and taking the flexplate with it, reducing the required range of starter pinion throwout. That main drive chain setup doesn't really do much to hold the converter in place.
The next time you have the starter out, try to GENTLY push or pry the flexplate and TC back to the pump hub shoulder. If it moves back significantly (more than a few thousandths) you may have found the problem.
Old 06-12-2007, 07:10 AM
ok so i put in the new starter, and did check for any movement with the pry and pull. there was no movement at all. No the starter says no shim, but could a no shim be my issue with the length of the bendix coming out and going to far?
Old 06-13-2007, 03:29 PM
wrightz28's Avatar
Okay, yes, but reverting back to a question already covered: what caused the initial replacement of the starter, to wich you replied, this issue
Old 06-13-2007, 06:16 PM
The solenoid just died. I mean i figured i would just replace the full starter rather than the solenoid. i did nothing different from taking it out to putting the new one in!
Old 06-14-2007, 09:11 AM
wrightz28's Avatar
Okay, so this problem has now started as a result, right??? Then the issue is that it is not shimmed properly. Which is why I stated when you replied that this is the issue for the starter being replaced in the first place, I elminated shimming.
