Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 06-11-2007, 03:44 AM
hahapopcorn hahapopcorn is offline
turbo internal upgrade?
I have a big 16g turbo and the blades are all messed up on it..guess it sucked somethin in, well anyways i heard that you can upgrade the internals for it and make it a 'sleeper' 20g turbo? i've never heard or seen it before..but then again im a newb but around how much would it cost to do that? thanks
Old 06-11-2007, 10:37 AM
Mikelb's Avatar
Mikelb Mikelb is offline
Send a message via AIM to Mikelb
Re: turbo internal upgrade?
you're effectively looking at doing what FP has already done:
http://store.forcedperformance.net/m..._Code=Turbo-FP
They won't disclose their parts, but IIRC, I was told it's a 20G slapped in a 16G housing.
Now, I'm not sure if you would have to machine the compressor housing but the 20G wheel might fit into the housing.
Here's the specs on the compressor wheels:
Turbo ................Ind.......Exd....Comp housing
"Large" 16G...16G 1.892...2.680...16G
20G ............20G 2.070...2.680...17C
The turbines are the same
TD05H 1.9302.200070 - 7cm
Originally Posted by Blackcrow64
I write a lot... I wrote one song about this chick I was messing with that was uhhh... Well, lets just say I called it "Forbidden Love"
1991 Eagle Talon TSI - Broken
Head removed, block broken, trans in hatch
1991 Eagle Talon TSI AWD- in pieces
3" exhaust, rebuilt bottom end
Project: Assemble the Eagle is underway... and now with AWD
2003 Lancer Evo 1630hp/1593ft lb tq
Old 06-13-2007, 12:48 AM
Black99GST's Avatar
Black99GST Black99GST is offline
Send a message via AIM to Black99GST
or sbr, with the bastered 20g...
Old 06-13-2007, 02:02 AM
kjewer1 kjewer1 is offline
AF - Advisor
The comp cover will certainly need to be cut for the larger wheel. You can stay with the 5H turbine side, but I prefer my 20Gs with the 6H wheel.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
