Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 10-28-2002, 02:55 AM
pixiestikjunky1 pixiestikjunky1 is offline
NOS and turbo for a 90 Accord LX
I recently picked up a 90 Accord LX, So far I've done mostly minor add-ons. I've done a lot appearance wise, but not a whole lot for performance.... So far, I've added a DC intake, header, an exhauset setup, as well as a Jet chip. I'm looking at adding an intercoler, turbo, and nos. My question is what kind of engine upgrades do i need to do so I don't fry my engine with the Nos, and who makes a good turbo for my car. Any hellp would be greatly appreciated, since I'm relatively new at this. Thank you
Old 11-12-2002, 09:32 AM
turbo2nr's Avatar
turbo2nr turbo2nr is offline
Send a message via AIM to turbo2nr
TURBO N NOS dammm
first of all you shoud look into doin a motor yo a more efficient h22a motor if u accord doesnt have 1 which i doubt.
you shoul get a knife edged crank wit crower rods and je pistons that lower your compression n some better piston rings also get a head gasket to lower your compression . lower compression = more hp when you turbo or nos. also you need 2 up grade your fuel system and ignition system, get a msd n haltec unit n dat should be fine. also u might want 2 get a new valve spring package, cams and camgears too.
plz bulid ur motor first cause hondas suck when it commes to boost. stock they can only take bout 6psi. puttin nos n turbo will fry ur motor if you dont have it propaly built.
Old 11-13-2002, 04:07 PM
FREED0MFiST FREED0MFiST is offline
Send a message via AIM to FREED0MFiST
fuck getting a new motor *sigh* getting sick of everyone suggesting swaps. I'll have to disagree with honda ENGINES only being able to run 6psi. you can run more than that without building the engine, just need fuel and ignition. ive seen hondas without ignition/fuel/internals running 9psi when they race fine... id get fuel/ignition just to be sure though.. then i bet you could easily do 10psi with tuning. if your just doin nitrous you should be able to run a 50 shot fine.... assuming your car is otherwise in good mechanical condition and you dont have an insane amount of miles
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 05:32 AM
