Go Back   Automotive Forums Car Chat > Chevrolet > General Discussion
Old 06-10-2007, 07:34 PM
relic7680 relic7680 is offline
Question double hump heads-1.94 or 2.02 identification
i have a set of #3890462 double hump sbc heads dated sep '66. they are 64cc/straight plug/no accessory holes. my casting # book gives 3 different applications as follows:
327 66-68 PASS/CAMARO/NOVA/CHEVELLE 4BC Q-JET 275 HP
327 67 CORVETTE 300,350 HP
302 67 CAMARO Z28 HI PERF
now does the date code on the heads correspond w/ the year of the car or does the year info in the book mean that my heads are definitely from a 275hp engine? and short of measuring the valves with a dial caliper, how do i determine if mine are the desirable 2.02" intake heads? any help would be greatly appreciated.
close enough for government work........
'91 C2500 Silverado (8600GVW)
'89 Suburban R1500 Silverado
'76 GMC Sprint Classic
'76 El Camino Classic
Old 06-10-2007, 07:52 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: double hump heads-1.94 or 2.02 identification
In short, you really can't without pulling the heads and looking at the valves. A 9-66 date could mean a 1967 model year.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 06-10-2007, 08:35 PM
heads are not on a motor so i guess i'll just measure...still doesn't guarantee that somebody didn't retrofit the bigger valves if they come out to be 2.02"
Old 06-10-2007, 09:26 PM
silicon212's Avatar
Confoundingly Lucid
There is no difference in the castings between 1.94 and 2.02 intakes. You can easily retrofit a set of 1.94s with 2.02s, the biggest thing would be some mild bowl blending and if necessary, unshrouding.
Old 06-10-2007, 10:41 PM
well the heads look to be pretty untouched (even paint appears to be original) so whatever the valves measure out to is what they probably started as...thanks for the help
