Go Back   Automotive Forums Car Chat > Mitsubishi > Galant
Old 06-10-2007, 06:45 PM
240SX_89 240SX_89 is offline
Exclamation Transmission?
Just today I began to have problems with my transmission. The problem is that every time that it tries to go into 3rd gear it kind of studders and has trouble going into gear. Could changin the trans fluid help with this problem or do I need to get a new transmission? Also what kind of fluid do I get, because I have heard about other people changing there trans fluid and did not use the stuff you get from the dealer and a year or so later the trans failed and had to be repaired or replaced. It is a 94 Galant ES with automatic transmission and 192K miles.
Thanks
JV
Old 06-18-2007, 09:15 PM
Bronxbombr Bronxbombr is offline
Re: Transmission?
it could need a flush, or it could be failing. Only use the fluid from the dealer, its pricey but its worth it.
I have spare A/T's if you need one.
Old 06-21-2007, 08:53 AM
Re: Transmission?
I replaced the ATF with some universal fluid and the filter was in desperate need for replacement. Problem is fixed for the most part but every now and then it does the same thing. Could it be because I didnt use the dealer stuff. How much do the dealership charge for the fluid?
Thanks
