| Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible. |
Slight overheating...Possibly FMIC
Ok so i did about 60 miles round trip in the gsx today, the longest ride ive takin the car since i installed the FMIC. The temp gauge would go up and i checked the logger and was running around 240-250 degrees. I was doin about 72mph or so with 3k rpms @ around 100 degrees outside air temp. I slowed down to 50-55 and it went right back down. It has never happened before, which leads me to believe it was caused by the FMIC and the 100 degree weather we had today. Tomorrow i plan on rewiring the radiator and AC fan so they both kick on together. So I was thinking if i were to run an extension to the power wire on both fans and connect them together, would both of them come on? So when the radiator fan kicked on the AC would kick on, and if i were to turn on the AC both of them would turn on. Am i on the right track here? I had planned on pulling the AC compressor relay, eliminating the need for me to wire any kind of toggle switch to control the fans. Then when i want AC just throw the relay back in. Does this sound like it would work? Normally my engine temps are around 190 so i dont think its the thermostat, but does anybody know if they make any thermostats for our cars that will open at a lower coolant temp other than 190 or is that the standard? Thanks in advance
98 Eclipse GSX-EVO3 16G, BC 272's,ETS FMIC and short route piping,TRE Stage 2 tranny, ACT 2100, Walbro 190lph,550cc jectors,SAFC NEO,GM MAFT, AEM UEGO wideband,ported SBR Exhaust Manifold,O2 Dump,EBay Intake,3" megan downpipe and catback exhaust,TurboXS boost controller,HKS BOV,Ebay Short Shifter,Boost Gauge,Symbroski shift kit & shift cable bushings, RRE catch can 94 Talon 1.8L-SOLD 02 Civic EX- Daily driver (staying stock) |
Re: Slight overheating...Possibly FMIC
you have a few options
lower thermostat, yes they make them wire the fans so they are always on run air ducting to get more air to the radiator from your description, i would go for the air ducting
now - 2000 civic soon - 2002 is300
I have the same issue I believe. I was doing some tuning the other day and after a few hard runs the temp gauge was up about 3/4 of the way. The fan was running and the motor cooled down after a few minutes. I have never had this issue before but it just started getting really hot here so I think that may have something to do with it.
98 Eclipse GS Turbo Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio 1981 Chevy Scottsdale 1987 Nissan 300zx - Chump Car 2001 BMW 325i - DD |
Don't connect the power wires together, the current draw will be too high for that circuit. Connect the two relay trigger wires together, so when the ECU commands one fan to come on, the other comes on as well, powered by it's own circuit. IIRC, there is a VFAQ for this.
I needed two fans when I went to a full sized FMIC on the 2g, the main big fan alone wasn't enough. The bumper design doesn't lend itself well to big FMICs and adequate cooling, at the same time.
Kevin Jewer RWD Talon - 7.92 at 180 Mightymax - 10.7 at 125 |
Thanks for the ideas. I wired the fans, but not by the power wires, like i was originally going to do it. Just like kevin said theres a vfaq, and i just ran a jumper wire to both relays and they both work when either the temp gets above 205 or the ac is turned on. I also added 12 oz of that redline water wetter, and sprayed down my radiator and condensor to get all the bugs and leaves out of it. Im in the process of thinkin how to rig some kind of air ducting that wont take away from the outside apperance as well. Its fine driving around town, but the real test will come when i make another long trip at higher speeds.
