Go Back   Automotive Forums Car Chat > Dodge > Durango
Old 06-10-2007, 04:02 PM
kuntorm kuntorm is offline
2001 Durango AC not Cold
For the past month my AC has been intermittingly switching between cool and warm. There is no mist coming out and it is blowing air.
I finally took it to mechanic, and he found no problem. He said it was probably the expansion valve. He said that with this model their have been problems.
So 500 dollars later, my ac is still blowing hot air.
Any insight?
Old 06-11-2007, 05:37 PM
DurangoDave DurangoDave is offline
Re: 2001 Durango AC not Cold
WHAT????? For $500 he reported 'no problem'?? Don't tell me he actually took your money for that answer.
So how did he explain to you that intermittently switching to warm air was no problem?
Sure, it could be the expansion valve, or it could be a number of other things, but if he concluded expansion valve, THEN FIX IT. A competent A/C technician will have no problem figuring out and fixing the problem.
Sorry, but that resolution is absurd. Go back and get a straight answer and a fix for your $500.
Dave
Westminster, MD USA
Old 06-11-2007, 10:15 PM
B1G BLEU B1G BLEU is offline
I'm betting the blend door is sticking.
Old 06-12-2007, 07:51 AM
(PS - I agree with BB...that's one possibility).
Dave
Westminster, MD USA
Old 06-29-2007, 10:58 AM
raamedicva raamedicva is offline
I have spent about $1000.00 on my ac, and it is not working. If it is the blend door, how do I fix it. I understand that it is mostly labor cost involved with this fix.
Old 09-16-2007, 10:05 PM
jeep lover jeep lover is offline
you probably have it fixed by now, but the blend door is absolutely right on most of the time. See my response earlier today to a thread about the same issue. Disconnect the heater hoses, splice them together, and run it for a while to see if that helps. If it does, leave it until winter, then hook the heater back up. Beats the hell out of giving someone $1000 for all the labor involved.
Old 09-20-2007, 09:32 PM
dirtdriver11 dirtdriver11 is offline
how exactly do you splice the hoses together?
Old 09-22-2007, 10:37 AM
Actually fairly easy. At auto parts house there are bubble paks of heater hose splice/repair parts. Buy one the right size for your hoses, take the hoses off the heater at the firewall, and splice them together. Use a hose clamp on each side. If this doesn't work, then you know there are other issues. But for a couple of bucks and an hour work, it might do the job during the summer.
Old 09-24-2007, 12:38 PM
TCHRISD TCHRISD is offline
How do ID the heater hoses?
Old 10-26-2007, 04:23 PM
n8zdogg n8zdogg is offline
If you havent already cut and spliced your hoses a shut off valve can be put in the inlet side of the heater hose. Its much easier and less messy to reverse when you need the heater.
