Go Back   Automotive Forums Car Chat > Honda > JDM Motor & Parts info/chat
JDM Motor & Parts info/chat Discussions on Mugen, Spoon etc. Plus, info on motor swaps (b18 's, b16's h22's etc) and other JDM info!
Old 06-10-2007, 03:11 PM
JDMZC1 JDMZC1 is offline
Send a message via Yahoo to JDMZC1
Exclamation Too much fuel need help
I need a little help i have a 1990 CRX SI with a JDM DOHC ZC mototr in it. The car is spitting so much fuel out i believe the system is RC 440 cc injectors a 255 lpm walbro fuel pump and the fuel rails i am assuming are stock. What can I do to regulate the fuel. The car sometimes smells so much like fuel it is annoying i was thing about getting an adjustable fuel pressure regulator by AEM but which one would i get seeing as it it a ZC motor. Could a universal one work? Also would an MSD system help? Thanks a lot
Old 06-10-2007, 04:31 PM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
Re: Too much fuel need help
Get rid of the injectors, they are way too big for your setup. Get some 220cc-250cc, anything more will be overkill and cause the engine to run too rich. That fuel pump is overkill as well, even walbro's 190lpm would be overkill.
The fuel pressure regulators, like AEM's, will only allow you to raise fuel pressure, it won't let you lower it. And don't waste your $ on an MSD ignition, it will do nothing for your setup.
Old 06-10-2007, 10:45 PM
Hey thank you for your help that is what I figured because it is a good car I just can't figure out why the guy would do that. I am trying to make the car a street car it just seems like there is a lot of work to be done again thank you.
Old 06-11-2007, 03:54 PM
Greenblurr93's Avatar
Greenblurr93 Greenblurr93 is offline
Kind of a Big Deal
Send a message via MSN to Greenblurr93
240cc are factory... i would save those for a turbo setup if you plan on doing one in the future.
