Old 06-10-2007, 02:52 PM
hgoffman hgoffman is offline
Wheels Seem to be Grabbing
I have a 1998 Winstar and just recently the passenger side wheel seems to start grabbing for a while and then back to normal.
Old 06-10-2007, 09:23 PM
phil-l phil-l is offline
Re: Wheels Seem to be Grabbing
What do you mean by "grabbing"?
Are there other symptoms you can share?
2000 Windstar LX 3.8
1995 Contour GL 2.5
1986 Mustang GT 5.0 --> Sold, but missed on sunny days
Old 06-11-2007, 02:13 PM
lapin_windstar lapin_windstar is offline
Does it feel, for instance, as if the brake were being applied only on one side?
Old 06-13-2007, 04:01 PM
Exclamation Re: Wheels Seem to be Grabbing
Yes, we had new brakes installed on all four wheels not to long ago. Is this
being caused by the ABS system?
Old 06-13-2007, 05:24 PM
garync1 garync1 is offline
This could be caused by a sticking caliper.. Would not think ABS would cause this unless you are braking at the time. If its grabbing after you release the brakes then it must be the caliper..
Old 06-15-2007, 10:39 AM
LeSabre97mint's Avatar
LeSabre97mint LeSabre97mint is offline
Hello
I had the friction material come off of one of my rear brake shoes (about 2 years old) and cause the wheel to lock up. The friction material was floating around in the drum loose and would get jamed at times. I also had just adjusted my rear brakes up which is something that shouldn't need to be done if the parking brake is used. However, I when the friction material came off the brake pedal had to be pushed farther down like before the brakes had to be adjusted. I would recomend to bring it back to where you got the brake work done if you don't feel confortable in removing the rear drums and inspecting.
Regards
Dan
Wiswind's Windstar repair pics http://community.webshots.com/album/201931518cScpNK
Photos of my repairs: http://dansautopictures.shutterfly.com/
Check this out:http://threewheelmotorcyclemetro.shutterfly.co
A must read about problems Windstars have: http://www.automotiveforums.com/vbul...d.php?t=672854
95 Windstar 240,000+
98 Windstar 136,000+ 09-25-2008.
85 Dodge 1 Ton Snow mover gas hog
91 Mazda Protege free beater
SW MN
