Go Back   Automotive Forums Car Chat > Oldsmobile > Bravada
Old 06-10-2007, 02:08 PM
ericn1300's Avatar
ericn1300 ericn1300 is offline
AF Premium User
92 bravada ball joints
Hey Chris,
I remember a long time back you posted a visual inspection for ball joints on the Bravada. I couldn't find that post again, could you tell me how to do it?
I drove the Bravada for the first time in a long while and it was so sloppy I couldn't believe the load levler was putting up with it. I just pulled the idler arm and it's shot. Almost 3/4" play in it.
Also anything else I should be looking for? The pitman arm seems ok for now.
Thanks, Eric
Old 06-10-2007, 03:54 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: 92 bravada ball joints
Sure Eric,
Look at the grease fitting on the lower ball joint. It's screwed into a nipple on a plate inside the ball joint. As long as that nipple is protruding the cover, your ball joint is ok but when it recedes through the cover, it's considered worn out.
Since my '92 is back in retirement, I took it on it's first monthly "keep'er limbered up" ride this morning. I felt a resonant vibration in the floorboard & seat until it warmed up so it's going up on jackstands...I'm guessing low lube somewhere like the transfer case or the front pump bushing on the trans is going away which means a trip to the trans shop some of these days.
Does your right knee hurt after driving your Bravada for ant distance?
Old 06-10-2007, 06:11 PM
ericn1300's Avatar
AF Premium User
could just be the pumps, gears and clutches were dry from sitting so long, vehicles need to be driven regulary. or it could be something as simple as flat spots in the serpentine belt from sitting. check the fluid levels and see if the problem goes away when you restore it to regular service before heading to the tranny shop.
i use the cruise control in the Bravada so i can stretch out while driving distances, but my left knee sure did hurt after driving the 50 gmc out to the dump last week. man that's a heavy clutch. something to be said for those new fangled hydralic clutches, and about getting older.
Old 06-11-2007, 09:20 AM
AF - Advisor
Does the GMC have the pedals go through the floor with linkages under the floorboard? Seems like Dad's had a pedal he pushed to start the motor....man that's taking me back,lol.
Old 06-11-2007, 06:33 PM
ericn1300's Avatar
AF Premium User
yes it still has the floor starter next to the gas pedal. it goes thru the floor board and is a direct mechanical linkage to the starter
