Go Back   Automotive Forums Car Chat > Oldsmobile > Eighty Eight
Eighty Eight Includes the '97-'98 Regency and '96-'99 LSS Models
Old 06-10-2007, 01:30 PM
Jaggs69 Jaggs69 is offline
Angry 1995 Olds 88 Wont start
Okay it started by occasionaly not starting. Relays owuld click but engine would not turn over. After running the gear shift thru PRNDL several times it would start and no problems rest of the day. Finally it just would start anymore. I have cleaned all the battery cables, bypassed the VATS and replaced the neutral safety switch. Any other ideas? I still get relays clicking but no cranking.
Old 06-10-2007, 07:16 PM
maxwedge maxwedge is offline
A990 racer
Re: 1995 Olds 88 Wont start
Welcome to AF, I assume you mean the starter will not turn the engine, does the dash security lite stay on when this happens.
Old 06-11-2007, 09:33 PM
Charles89 Charles89 is offline
I had the same problem. and my security light stayed on.
Another person suggested the Ignition cylinder.
Old 06-12-2007, 07:27 PM
auto trainy auto trainy is offline
I would start first to see if the starter solenoid is getting power when the key is turned,if it is then I would then suspect the starter,if not then I would go with the key switch and see if its putting out power just make sure you have correctly bypassed the vats system,good luck.
Old 06-12-2007, 08:48 PM
Mickey#1 Mickey#1 is offline
When you turn the key to the run position does the security light stay on? If it stays on then the bypass isn't working properly.
Check to see if you're getting 12 volts to the small wire (purple?) on the starter solenoid when key is in the start position.
Old 06-14-2007, 09:49 PM
I dont know if it was dumb luck or not, but today when mine wouldnt start, i got out and played with the "Purple" wire on the starter, and it started right up.
