Go Back   Automotive Forums Car Chat > Kia > Sportage
Old 06-10-2007, 12:59 PM
kbrown5228 kbrown5228 is offline
2002 Kia Sportage misfiring
I have a 2002 Kia Sportage that cylinder 1 is misfiring. I have changed the plugs, wiring and ignition coil. Works for day or two and then starts misfiring again. Any ideas on what's wrong? Is there a sensor for cylinder 1?
Old 06-10-2007, 11:52 PM
hvac1000 hvac1000 is offline
Re: 2002 Kia Sportage misfiring
Did you do a compression check?
Old 01-25-2008, 08:21 PM
grrr1827 grrr1827 is offline
Question Re: 2002 Kia Sportage misfiring
We have the same problem with our 2000 Sportage have you found a solution??
Old 01-25-2008, 08:26 PM
trackertrouble trackertrouble is offline
I'm having a misfiring problem with cylinder #3 on my '97 tracker, same thing, did plugs, wires, dist cap/rotor, runs ok for 9 - 10 miles, 1-2 days, then same problem again.......seems to be after it warms up a bit, then happens again, also check engine light comes on and latest thing is white milky substance on dip stick. please let me know if you find out solution......
