Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 06-10-2007, 11:49 AM
terrykui terrykui is offline
Power window motor assembly removal
Can anyone tell me how to remove the power window motor assembly (left front driver side) from a 1997 Camry?
I have already removed the panel from the door and after removing the last 5 nuts, the motor assembly is still stiffly attached. I would greatly appreciate if you can also provide some pictures for me to look at.
Thanks
Old 06-10-2007, 05:20 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Re: Power window motor assembly removal
Might be apples and oranges but, I recently changed the same assembly on a 94. The motor was held by 3 nuts and the guide was held on by 3 nuts, top/bottom/middle. 6 total nuts. Sorry, no pics.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
Old 06-11-2007, 06:11 AM
DFBonnett DFBonnett is offline
OP, You might want to consider replacing the whole regulator/motor assembly as a unit. Check Ebay for the parts.
Old 06-12-2007, 01:07 PM
RIP,
You are right, there are 6 nuts to remove. But in addition, you need to remove the window glass first (remove the 2 bottom bolts holding the glass) in order to remove the power window assembly. I found out about that extra step by looking into a Chilton's repair manual, not the Toyota repair manual.
Old 06-12-2007, 01:34 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Yup, the brain remembers now. I did remove those two bolts but, I just slide the glass up and held it there with duct tape.
OBTW - After I changed the drivers window regulator, I ran all the windows up and down and found the drivers side rear window wouldn't go up. Arghhhhh!!!! I can change a regulator blindfolded now.
