Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 06-10-2007, 11:12 AM
montie51 montie51 is offline
Angry 2000 impala LS stalls
Any Ideas why my 2000 Impala LS with 3.8 engine, stalls when I try to start it . It takes up to three attempts before it will start. This happens on a cold start. If I turn the key to on 3 times before I try to start it will start on the first try.
Old 06-10-2007, 04:40 PM
Gems Gems is offline
Re: 2000 impala LS stalls
Does the engine fire and then stumble and stall about a second or two later?
Go Mark Martin!
Old 06-10-2007, 06:03 PM
Not on the first try,on the second or third try it stumbles and stalls. When it does start it sort of reves up, and you can smell a gas oder. It seems to be doing it all the time now, not just when it is cold.
Old 06-19-2007, 08:14 AM
zoemayne zoemayne is offline
Im having the apparently same problem with my impala. Last night it finally didnt start so i had to abandon it. I'll try to start it up again this morning if it does not start I think im gonna try to replace the starter......If that does not work I might replace the fuel pump (w a new on) b/c I replaced it with a used one a few months back. I posted a thread up a while back. You can check it out. Also I have a 2000 Impala 3.4 ~91K miles. http://www.automotiveforums.com/vbul...d.php?t=699821
Old 06-20-2007, 11:04 PM
I got it towed to a friends house and he easily told me it was the starter. So he changed it and it is working fine now. So it was the starter...................
Old 08-05-2007, 08:54 PM
Turned out to be the fuel pressure regulator.
