Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 06-10-2007, 09:48 AM
tee89 tee89 is offline
ypipe
need help cant get the left side to bolt on.. it looks like it could be bent just a hair what can i do to fix it..
Old 06-10-2007, 01:00 PM
97Bird's Avatar
97Bird 97Bird is offline
Re: ypipe
Buy a Mapp gas torch (similar to a propane torch but burns much hotter) and heat the pipe red hot at the bend while you try to bolt it into place. Be careful that you don't burn yourself or light something on fire under the car while doing this! Watch out where you are pointing the flame!
The Original 97Bird
Old 06-10-2007, 02:21 PM
Re: ypipe
thank you I will try that.. just 18 years old learning as i go..with a little help from here.
Old 06-11-2007, 08:08 PM
97Bird's Avatar
Re: ypipe
The best way to learn is by doing. Don't be afraid to ask questions here. We all started at sometime and still might not have all the answers to your questions. I should have also told you not to forget to wear safety goggles! Be sure to heat the pipe evenly all the way around it and don't hold the torch in one spot too long or you'll burn a hole through it.
The Original 97Bird
