Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 06-09-2007, 08:11 PM
stinkyone stinkyone is offline
rotors?
I'm replacing my pads and rotors soon and was wondering if cross drilled and slotted rotors are worth getting
Old 06-10-2007, 01:17 AM
jammyjim jammyjim is offline
Re: rotors?
Cross drilled rotors are a bit lighter and have more surface area for better cooling. They look cool if you have spoked rims. I would not suggest slotted rotors unless you are doing serious racing. They help with brake fade as the edges tend to scuff the pads and remove the polishing that occures under heavy braking. Because of this, your pads will wear much quicker. If you want to increase your braking power, I would suggest you replace your rear drums with discs.
I hope this helped you decide.
Old 06-10-2007, 09:44 AM
ZL1power69's Avatar
ZL1power69 ZL1power69 is offline
GM S-Series Mod
Re: rotors?
i'd say they aren't worth the money and they will eat regular pads up faster. just go with stock replacements but make sure the ones you get are made in china or canada as the steel is of better quallity and will last longer. The OEM rotors are made in mexico and flake appart and eventually crack.
2000 Chevy Blazer ZR2
Performance Mods: Numerous
Suspension Mods: Some, but not enough
Exterior Mods: Just Right
1987 Buick Turbo T Dark Red
Low 11 sec sleeper
.030 4.1 block, PT6262E, & other odds and ends....
My Cardomain
Old 09-26-2009, 08:50 PM
TownCarTechi TownCarTechi is offline
Re: rotors?
I admit this is an old post but I didn't want to create a new one since my question is about rotors. I just replaced the front rotors and pads on my daughter's 99 GMC Jimmy. The old rotors were worn to 1.129" and 1.137" and Pep Boys told me the minimum spec is 1.14", so I purchased new rotors. However, I was very surprised to find that the new rotors measured 1.158" on one and 1.155" on the other. This gives only 0.015 - 0.018" before the rotors are worn out of spec. This seems unusually low to me, or I am just out of touch with the reality of rotor manufacturing?
Old 09-26-2009, 09:26 PM
wafrederick wafrederick is offline
Banned
Re: rotors?
Another thing to check are the fins,they rust out and you will have further problems with warping rotors.If you see this happening,pitch them and get new ones.Also make sure you clean the protective coating off the new rotors with brake clean.Avoid ceramic pads too,they are known for eating up rotors and are noisy due to the metalics in them.Plus they are harder to break in.
Old 09-27-2009, 09:29 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Re: rotors?
It used to be that rotors were thick enough that they could be machined (ground down and resurfaced ) on a brake lathe at least once, sometime 2 or 3 times, when new pads were installed.
In recent years, the aftermarket has been flooded with inexpensive rotors... usually made overseas (Usually China, but I have bought some that were made in Brazil and Argentina, of all places).
These cheap rotors are priced to be competitive with the cost of machining rotors. The idea is that, instead of paying $25 for resurfacing, one will pay $25 to 35 and get all-new rotors. However, these rotors are not only cheaper than, but also thinner than OEM and usually are not thick enough to resurface. Just use then once and throw them away.
