Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon > 1st Gen 95-99
Old 06-09-2007, 06:33 PM
ikeyballz ikeyballz is offline
Send a message via AIM to ikeyballz
help! air conditioning..
ok..so i took apart the bottom half of the passernger side console cuz i had a leak from the AC unit there..
i found the blower motor covered in water, the evaporator was sort of corroded.. so i havea big question... where is the water supposed to go? where is the hose that drains?!
Car:
1997 M6 SS Camaro [ white ]
285's in the back
all else = STOCK.
Old 06-12-2007, 05:10 AM
Re: help! air conditioning..
ookay solved it.
if anyone else has this prob, heres what to do..
take off the glove compartment (take off bottom screws, angle it out)
look @ rubber plug that goes into the evaporator housing thing.. (has wires going in)
take that off, look inside, look to see if the evap is covered in grime if it is: get degreaser/cleanser.. clean it off..get a air hose and spray the SHIT out of the back of it. theres a little plug thing behind the evap on the bottom, its the drain..
after you do that, go under the car, spray the shit out of the drain from the bottom up...
do that ac ouple times, then spray water onto the evaporator..see if it leaks down nicely.
it shouold
Car:
285's in the back
all else = STOCK.
Old 06-12-2007, 01:31 PM
das2123 das2123 is offline
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
Good advice.
2003 Dodge SRT-4
