Old 06-09-2007, 12:28 PM
novagard novagard is offline
Speed Sensative Locks
I have a 2001 SE sedan. Does anybody know how to disable the speed sensative locks? I hate these things. Thanks in advance.
Old 06-09-2007, 04:01 PM
Johnny Mullet's Avatar
Johnny Mullet Johnny Mullet is offline
Send a message via MSN to Johnny Mullet
Re: Speed Sensative Locks
The Dealer can do this on most models with the diagnostic computer. They will charge you of course.
Old 06-14-2007, 12:11 PM
97TaurusGuy's Avatar
97TaurusGuy 97TaurusGuy is offline
Send a message via AIM to 97TaurusGuy
Autolock (if equipped)
No need to go to the dealer. The procedure to diable the Autolocks is on page 75 of your owner's manual. I have copied below:
The autolock feature will lock all of the vehicle doors when:
² all doors are closed
² the engine is running and
² you shift into any gear putting the vehicle in motion
The autolock feature repeats when:
² any door, except the drivers door, is opened then closed while the
² you put the vehicle in motion
Deactivating/activating autolock
There are 2 methods to enable/disable this feature. One through your
dealer and the second with a door lock sequence using the following
instructions:
1. Turn the ignition key to RUN, then press the door UNLOCK control
button 3 times.
2. Turn the ignition key to OFF, then press the door UNLOCK control
button 3 times.
3. Turn the ignition key to RUN, within five seconds press the door
UNLOCK control button 1 time.
The user should receive a horn chirp to indicate the system has been
altered.
Pressing the power door UNLOCK control button again will toggle the
Autolock/Relock states.
² Turn ignition to OFF to exit.
"Save water, shower with a friend"
