Go Back   Automotive Forums Car Chat > Nissan > Sentra | 200SX (USDM FWD)
Old 06-09-2007, 07:38 AM
sentrapains sentrapains is offline
nissan etesting (sentra)
1994 Nissan Sentra 1.6L TBI, Standard Tranny, 2dr
Ok I have done 5 e-tests and i'm so close here is what happened on my last 2
Curb idle
HC ppm limit:200 reading:77
CO% limit:1 reading:0.04
40km/h test
HC ppm limit:72 reading:85 = FAIL
CO% limit:0.4 reading:0.34
NOx ppm limit:550 reading:69
Here is the list of thing I have put into it
New Cat converter
Advanced Timming
New O2 sensor
New Plugs (bosh platinum 4)
I checked the EGR valve it's working and mechanics can't seem to tell me what els to do.. any ideas on how I can lower HC
Im running Regular grade fule with Guarenteed to pass formula
Maybe try ethanol/fule blend???
The mechanic said the limits for that specific vehical was LOW and not very fair for the year of the vehical. I kind of agree.. He showd me paperwork for 2003 Honda RAV4 had limit of 200 and blew 80.. I personaly think the government dosent want my vehical on the road because it's to good on gas.
Thanks in advance,
Nick
Old 06-09-2007, 07:53 PM
vgames33 vgames33 is offline
Re: nissan etesting (sentra)
Ack! Get those plugs out of there. I've heard nothing but bad things about those Bosch +4s! Other than that, I don't have any real advice..... I don't know much about emissions...
Old 06-10-2007, 07:31 AM
nismo_pilot nismo_pilot is offline
Send a message via AIM to nismo_pilot
was your car warmed up and if so for how long?
2005 Aztec Red Spec-V
Nismo header, ES MMI, AEM CAI, UR Pulley, TB Coolant bypass, TWM SS, Kumho Ecsta's, 2x JL Audio W0 subs
9.02@ 84.4mph in the 1/8th....... Driver > Car
Old 06-11-2007, 06:22 AM
The car was plenty hot I took it for 2 hr tour before the e-test... You think maybe changing the plugs to champion and gapping them higher would make it run more lean... the mechanic said if i could get the car to run more lean it would pass the etest.
oh i also did a computer dignostic on it .. the computer says everything is working fine
Old 06-11-2007, 12:36 PM
having it too hot will affect your emissions, id let it cool down for like 30 min before taking your test and see if it helps
Old 06-12-2007, 04:05 PM
Well i'm going to try using this Octane booster called NOS.. Says on the side of the box sapose to reduce hydrocarbons emissions.. Take 30 octane gas and brings it up to 90 octane. That should do the trick hopfully
