Old 06-08-2007, 09:45 PM
deltableh deltableh is offline
Send a message via ICQ to deltableh Send a message via AIM to deltableh Send a message via MSN to deltableh Send a message via Yahoo to deltableh Send a message via Skype™ to deltableh
Tamiya White Primer or Cobra Colors Black Primer?
I'm going to be painting a car using Cobra Colors Lamborghini Blu Monterey Metallic, and I want to know what the best color primer would be. The paint itself is a two part paint, with a lavender candy with pearls basecoat, and a candy blue topcoat. So I know the white will make it lighter, and the black darker. I just don't know which will give me the TRUEST color. Or should I spray primer, then spray some silver (which I'll have to go out and get) before I hit it with the base?
Old 06-08-2007, 10:26 PM
drunken monkey's Avatar
Razor Sharp Twit
Re: Tamiya White Primer or Cobra Colors Black Primer?
why don't you just test it for yourself on a bit of scrap?
AF's Guidelines
Read them.
Old 06-09-2007, 02:23 AM
Mr. Me.'s Avatar
Mr. Me. Mr. Me. is offline
Send a message via ICQ to Mr. Me.
I think white primer is that, what they use on real cars.
Old 06-09-2007, 08:21 AM
MPWR's Avatar
MPWR MPWR is offline
Image Hosting Exceeded
Use white or grey- for color, it doesn't really matter which. Leon always said that the pigment opacity in CobraColors (except Fire Pearls) was sufficient that it didn't really matter what color the primer was.
Fire Pearls were intentionally translucent, so they needed to be applied over black. Factory finihses like the Lambo Tricoat you're using are not transparent. Other than for Fire Pearls, I would stay away from black primer (I avoid white whenever I can, too). If you can use grey, it's nearly always the best option, as it allows the best viewing of flaws to be fixed. Personally when using colors that require primer of a color other than grey, I would always apply grey first. Fix whatever needs addressing and get the body perfect in the grey primer stage. Then if necessary apply a thin layer of whatever other color (black, white, pink...), and then apply the color.
So simple answer for your Lambo paint- skip both the white and the black. Get yourself some grey, and apply the color directly over that. Save the white or black primers for colors that need them.
PHOTOBUCKET SUCKS
Old 06-09-2007, 10:17 AM
Okiemodelbuilder Okiemodelbuilder is offline
The best and easiest way to test paints is with white plastic spoons. Real cheap too!!! Spray one with white primer, one with black, then hit 'em with the blue and clear and see which one works for you.
Completed Pro Touring Projects
...the pro touring experts
