Old 06-08-2007, 08:55 PM
carhacker carhacker is offline
Unhappy What is an Adaptive lamp monitor?
My 1995 Buick Lesabre has this "adaptive lamp monitor". What exactly does it do?
The only google hits I've found are lawyer talk on a patent site and a consumer page that says it costs $329 for parts and $65 in labor to fix.
Old 06-09-2007, 05:45 AM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Wink Re: What is an Adaptive lamp monitor?
This system will let you know when certain exterior light bulbs fail to light. You should have a display with eight LED’s indicating bulb status. When you first start the car, all eight indicators (LED’s) will light for a few seconds to indicate monitor system is working and then the lights will go out. When a bulb fails, an indicator will flash for a few seconds and then stay on until the failed bulb is replaced. (The bulbs are monitored, only when being used).
The bulbs that are monitored include; both headlight high beams, both headlight low beams, front & rear left turn signals, front & rear right turn signals, parking lamps including four tail lamps, right & left side markers, stop lights, including four rear & rear “high mount” and finally the back–up lights.
The “Adaptive Light Monitor Control Module” is located under the driver’s side dash and usually above the steering column. It has a large heat sink on the front of the module.
BTW, you can Click Here & go to "FIG 56" for a wiring diagram.
