Old 06-08-2007, 08:47 PM
Kev3399 Kev3399 is offline
Brake lights not working.
My right and left brake lights are not working, the brake light on the hood under the spoiler is though. I have changed the bulbs and checked all fuses. So what component would prevent the right and left bulbs from lighting brighter when I brake?(The light bulbs work like normal when I have my headlights on or turn signals on)
Any help would be appreciated, thanks.
Old 06-08-2007, 08:59 PM
Re: Brake lights not working.
Oh, and my car is a 99 Pontiac Sunfire
Old 06-09-2007, 01:59 AM
OverAllComa OverAllComa is offline
Send a message via AIM to OverAllComa
You said you checked the bulbs and fuses, which leaves wiring. So, get to tracing...
1992 Chevrolet Cavalier Z24 *R.I.P.*
3.1L MPFI (3.1 6cylinder Pushrod 12V)
1997 Chevrolet Cavalier Z24 *R.I.P.*
2.4L "Twin Cam" (2.4 4cylinder DOHC 16V)
2003 Honda Accord EX V6 - The new hotness
Old 07-09-2007, 07:17 PM
Knight2211 Knight2211 is offline
The power for the brake lights (other than the center light) go through the signal switch in the steering column. It has to do this to allow for the same light to be used for both signal and brake. Pull the steering column cover off and make sure that you have power going into the switch when you press the brakes, if you do, then make sure there is power going out (it goes to each side seperately). If there is nothing coming in, chase it back down to below the dash, if it is going in but not coming out, then you likely have to replace the switch.
