Old 06-08-2007, 07:45 PM
debian4life debian4life is offline
A/C Issues
I have a 1998 Ford Windstar 3.8L engine. I am currently not getting any air blowing out the rear A/C in the van. I am researching this on the forum here, but I was wondering if it might be another A/C issue I am having.
Whenever I go up a steep hill the A/C goes from blowing out the front vents to blowing out the defrost vents. Then as I crest the hill it switches to blowing out at your feet. When you get towards the bottom it it switches back to the front vents.
Any help would be appreciated.
Old 06-08-2007, 10:17 PM
busboy4 busboy4 is offline
Re: A/C Issues
Hi
I'll write more later and I'm sure others will chime in, but you have a vacuum leak in your A/C control lines. If you search on A/C and or defrost, or defrost only you will see others have had the same problem. Tracing the leak is the hard part.
Old 06-09-2007, 07:31 AM
wiswind wiswind is offline
Re: A/C Issues
When you are going up a hill, your engine is working harder...and the vaccum is lower.
With a vaccum leak in the air controls, it will be more noticeable with a lower vaccum to start with.
The temperature control is a separate function, and is electrical.
Where the air goes is driven by vaccum from the engine.
With little to no vaccum, the default position for the air is the defrost.
As busyboy4 said, finding the leak is the hard part.
Moderator for Ford Windstar room only
Links to my pictures, intended as an aid, not a replacement for, a good repair manual.
1996 3.8L Windstar
http://www.flickr.com/photos/4157486...092975/detail/
2003 Toyota Sienna pictures (not much there yet)
http://www.flickr.com/photos/4157486...781661/detail/
Old 06-09-2007, 08:08 PM
eciessau eciessau is offline
Re: A/C Issues
I am having the same problem. Front will blow cold but only on windshield. Back blows hot all the time at feet, checked the actuator and its working, will hold so it comes out of the roof vents but its always hot. checked the dash switch and its all electronic. what could it be?? Any help would be appreciated. thanks
Old 06-10-2007, 07:57 AM
Re: A/C Issues
Whats the best way to look for a vaccuum leak?
Old 07-11-2007, 06:47 AM
Re: A/C Issues
Turns out that the vaccuum issue was at the rear AC switch selector on the front heater control. Replaced and works great. Thanks for the help!!!!
D4L
