Old 06-08-2007, 07:41 PM
stealth702 stealth702 is offline
turbo conversion
hello i know smbody must have already posted this but i cnt find their forum
i wana make my 1991 dodge stealth rt into a turbo car ,not a twin turbo but jus a single turbo car
is there a turbo kit for my car?
Old 06-08-2007, 09:36 PM
VR43000GT's Avatar
VR43000GT VR43000GT is offline
Send a message via AIM to VR43000GT
Re: turbo conversion
If you are looking to go sing big turbo you need to be very mechanically inclined. I would recommend reading the FAQ. You can go very far with TT's and it is easier.
Old 06-09-2007, 06:45 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
Originally Posted by stealth702
i wana make my 1991 dodge stealth rt into a turbo car, jus a single turbo car
you asked. only 2 kits: #1 http://www.ipsmotorsports.net/produc...oducts_id/2306
#2 http://www.ipsmotorsports.net/produc...oducts_id/2292
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 06-10-2007, 04:43 PM
aorozco2's Avatar
aorozco2 aorozco2 is offline
quick question.
i cant tell by the pictures but are the manifolds the same lenght?
and what are the drawbacks to having a single setup with different lenght manifolds?
Wheels/brakes/Suspension:
Hawk HPS Brake Pads
R1 concepts cross drilled and slotted rotors
Megan Racing "Street Series" Coilover Kit
Adjustable control arms
adjustable toe arms
exhaust:
2.5" test pipe
2.5" cat back (angled out)
Misc.:
Short throw shifter
Soon to come:
TT Conversion w/AEM UEGO, AEM Ttru-boost, APEXi AFC II, solid motormounts, Dattalogger (hand held halo), etc...
Old 06-10-2007, 05:03 PM
Linebckr49's Avatar
equal length long-tube headers = increased exhaust gas flow.
different length headers = decreased/interrupted exhaust flow b/c one exhaust pulse may interfere with another.
93 3000GT base
