Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 06-08-2007, 06:50 PM
a_alyte a_alyte is offline
Brake Pedal Travel is Increasing?
'98 JGC Laredo 4.0
I recently noticed that my brake pedal travels a bit further before making contact. All brake pads were replaced back in '05.
Today I replaced the front pads (even tho they still had decent meat on them) & I checked the rear which still look good. The master cylinder has always had the correct fluid level.
What can cause an increase in pedal travel other than air in the system? What should I check next?
Thanks
Old 06-08-2007, 07:10 PM
kahjdh's Avatar
kahjdh kahjdh is offline
Re: Brake Pedal Travel is Increasing?
A leak, see if your lines are rusty and if so check for a leak. Other than that the master cyclinder or booster can be going bad.
ASE Master Certified before the age of 20
Current Cars:
2001 Chevy Silverado 1500 Z71 5.3L
1996 Acura Integra LS B18 1.8L
Past Cars:
1990 Buick Estate Wagon 5.0L
1987 Chevy S10 2.5L Tec Four
1995 Pontiac Grand Am 2.3 Quad 4
1996 Jeep Grand Cherokee Limited 5.2L AWD
1991 Ford Tempo L 2.3L
1992 Buick LeSabre 3.8L
1997 Buick Century 3.1L
1996 Lumina APV GT 3.4L
2006 Ford Escape 3.0L XLT
Old 06-08-2007, 07:36 PM
If my problem is a leak, wouldn't the fluid in the master cylinder go down, or not necessarily? The level has always been at the full mark.
Old 06-08-2007, 08:17 PM
kahjdh's Avatar
If the level doesn't go down it might be your booster going bad. My friend had a car where the booster went bad and the pedal just keeps going until its to the floor.
Current Cars:
Past Cars:
Old 06-10-2007, 08:23 AM
I looked through my Haynes manual & they actually provide a few test to assure the booster is airtight. My Jeep passed all the test. What should I look at next?
Old 06-10-2007, 10:45 PM
Bob D. Bob D. is offline
Not sure what you mean by "Brake Pedal Travel is Increasing"
Does the pedal slowly sink as you apply pressure or does it have more movement than you think it should have before the brakes engage?
If the former, I would bleed the brakes at all four wheels.
If the latter:
The rotors - checked for minimum thickness?
Checked the rear pads?
Checked the brake hoses? - the rubber parts of the hose can deteriorate/soften.
If all checks out, including a firm pedal, no excessive pedal pressure required to make a panic stop, you can engage the ABS system (if equipped) or lock the wheels during hard braking, then your brakes are good.
The only other thing that comes to mind is the pedal stop, i.e the bumper that limits the upward travel - if the pedal isn't stopping where it used to it will feel like there is too much travel.
