Old 10-27-2002, 09:12 AM
sugarcaddy's Avatar
sugarcaddy sugarcaddy is offline
Talking Another Panel Line Question- HELP -
Ok I know how panel lines are done but here is the real question:
Do you put on the panel lines before you gloss or after??
I have tried to put panel lines on a test car and the stuff Im using tends to bleed after the gloss is applied.
I have tried several types of .005 archival pens that say they are non-bleeding but still bleed if glossed over.
HELP!
:frog:
Scott
Fastest hunk of junk in the Galaxy.....
Old 10-27-2002, 09:59 AM
Daryl's Avatar
Daryl Daryl is offline
I glossed over my panel lines, cos i was afraid i might bury the detail under clearcoat.. and it didn't bleed.
You have to mist on the first coat to seal it in
Left is right. Right is wrong.
Old 10-27-2002, 10:12 AM
ZoomZoomMX-5's Avatar
I prefer to add panel line detail last. I like using acrylic flat paint, thinned out to flow into the panel lines, and I clean up any excess w/polishing compound. Glossy panel lines simply don't look realistic. If you use a pen or paint wash, do it last.
Old 10-27-2002, 10:32 AM
sugarcaddy's Avatar
Thanks I will try to see what a panel line looks like over gloss!
Scott
