Go Back   Automotive Forums Car Chat > Chrysler > PT Cruiser | PT Cruiser Convertible
Old 06-08-2007, 03:25 PM
juggernaut01 juggernaut01 is offline
timing help
I just replaced the water pump and timing belt on my wife's '04 cruiser.(2.4 L)
Everything worked out fine (except for all the specialty tools I had to borrow, and the fact I had to discharge the A/C.) I fully expected to fire it up and have no trouble. When I finally cranked it up it sputtered as if the timing was off. This is puzzling to me since the marks on the camshaft sprockets were lined up when I took them off and when I put them back on. Even after I spun the crankshaft around a couple time to seat the new belt the marks still lined up.
Anybody got any thoughts? Does anyone know the procedure if I did not put enough tension on the belt and it has slipped a tooth??
I'm not sure what to do from here.
any input would be helpful
Old 08-01-2007, 09:57 PM
toivo toivo is offline
Re: timing help
your timing marks are off. one of you timing gears is probably out 180 degrees. if you do a compression test you will have no compression which means you valve timing is out. the timing gears have a left and right mark on them and my guess is you swapped positions. that sucks. i know cause it happen'd to me. toivo
