Go Back   Automotive Forums Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 06-07-2007, 10:48 PM
jackaroo99 jackaroo99 is offline
Cast Iron FMX shifting problem
Had a trans fluid leak, but tranny shifting fine. Now leak solved (new seals around linkage shaft) but trans goes from 1st, only couple seconds in intermediate, then third. 351 Cleveland 2bl, downshift rod disconnected because it was a couple inches too short to cause a full throttle kickdown. Trans engages in intermediate when you use the shifter. Don't seem to be vacuum leaks, though the hose to the modulator was kinked a bit (now seems ok). Should I try changing the screw setting in the modulator? Thanks
