Go Back   Automotive Forums Car Chat > Chevrolet > Chevelle
Old 06-07-2007, 08:37 PM
scoopy03 scoopy03 is offline
Exclamation 74 chevelle engine+fire out intake
we have a 74 chevelle engine in a 83 buick regal and we have it timed at 7-9 on the crank we used the firing order 1-8-4-3-6-5-7-2 we had to hotwire the ignition from the starter bc the key wouldnt work from inside the car (but that is beside the current point of matter right now) we got it cranking over and it started to shoot fire out the intake. we have an hei distributor in it and mainly stock internals. this engine just seems to never run right. we tried on both compression strokes.
99 olds alero 2.4 DD
92 notchback with 460 carb'ed
Old 06-08-2007, 11:27 AM
bobss396's Avatar
bobss396 bobss396 is offline
Send a message via AIM to bobss396
Re: 74 chevelle engine+fire out intake
My money is on the distributor being 180 degrees out of rotation. The symptoms you describe are classic with that condition.
Old 06-08-2007, 10:20 PM
molhannah molhannah is offline
I agree, pull the # one plug out stick a finger in the hole and when you turn the crank over by hand, your finger will feel the compression. When the piston is at TDC line up the timing mark at O. Now remove the cap and see if the rotor is pointing at the # one plug wire. Good luck.
Old 06-10-2007, 05:42 PM
relic7680 relic7680 is offline
i worked on a '79 GMC truck w/ a stock 350 4bbl and had a very similar problem....distributor was in fact 180 off.
Old 06-13-2007, 11:19 AM
we tried 180 out.there's no more fire out of the intake.it is just not starting.
Old 06-13-2007, 01:26 PM
bobss396's Avatar
Well that's an improvement. Do you have spark and gas to the carb, is it flooded? When the #1 piston is fully up, does the rotor point to the #1 tower on the distributor cap? Like the post below, the timing mark should be on "zero". I'd continue hotwiring it if it worked before.
Bob
Old 06-13-2007, 03:30 PM
Bob
it has spark and gas.
Old 06-16-2007, 03:52 PM
joe68 joe68 is offline
CHECK your firing order and make sure they match the firing order correct placement of wires
1965 ss conver chevelle "red
1964 ss impala "red"
1964 bisq. gold 4 doors
current 1968 chevelle
" all apart at the moment"
Old 06-17-2007, 10:27 AM
we got it fixed it by doing the valve adjustment by removing the valve covers and loosening the rocker arms and adjusting them by the exhaust order and intake order. all chevy push rods must be movable by hand. u must be able to rotate them by hand in their proper locations.
Old 06-18-2007, 03:00 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
The proper way to adjust hydraulic lifters on a SB Chevy is to rotate a pushrod between the fingers of one hand, while tightening the nut with the other. The lifter must be on the cam base circle while making this adjustment. Once the pushrod stops easily turning, tighten the nut an additional 270 degrees (3/4 turn) to obtain the proper amount of plunger travel in the lifter.
The tedious and proper method to do this is to start with cylinder 1 on TDC compression stroke (NOT exhaust stroke). Make your adjustments to both #1 lifters, then turn the engine clockwise (at the balancer) 90 degrees, make the adjustment to #8, then another 90 degrees on through the firing order.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 06-22-2007, 06:45 PM
thats pretty much what i just said. but if u read chiltons its says to do it with 1 at TDC then turn it so 6 is at TDC so then you get the other rockers.
