Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 06-07-2007, 09:33 PM
dcmaynard dcmaynard is offline
Trailer Light Plug
I have a 96 EB and I want (need) to intall a trailer plug, However when I went to Checkers they told me that I would have to splice the plug since the lighting is hard wired in. is this true or not? I need to know quick since I am going to pick up my trailer this weekend.
Thanks
Old 06-07-2007, 11:44 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: Trailer Light Plug
If your Explorer has the auxilliary trailer wiring connector, it will be located under the driver's side (in the US) rear tail light, accessed from underneath the vehicle. Crawl under there with a flashlight and look for a circular plug with a rubber cap on it. If you find it, you should be able to just pick up a plug-and-play trailer wiring adapter and be good.
-Rod
Old 06-08-2007, 09:40 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Rod's advice is right. Also, check with parts houses to see if they have the adapter that plugs into the wiring harness on the driver side rear where the rear wiring splits.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 06-10-2007, 10:28 AM
Well when I went to Checkers they told me that the split was not it because it is off of the taillights and it goes to the license plate light. but if you say that it is it then I am going to get the plug and play
Old 06-10-2007, 05:01 PM
way2old's Avatar
TOKEN HILLBILLY
There should be a larger connection there where the right side lights come off the mauin wiring on the drivers side rear.
