Go Back   Automotive Forums Car Chat > Dodge > General Discussion
Old 06-07-2007, 06:17 PM
dogde2003overheat dogde2003overheat is offline
2003 dodge durango overheating nightmare
I have a 2003 dodge durango that is overheating. i have replaced water pump, thermostat, rad cap, and flush out rad no leaks present
Old 06-09-2007, 10:34 PM
B1G BLEU B1G BLEU is offline
Re: 2003 dodge durango overheating nightmare
What about the fan clutch? Is it OK only when your moving (after warmup)?
Old 08-23-2007, 06:24 PM
rhandwor rhandwor is offline
Check the temperature on the top and bottom radiator hoses you may have a plugged radiator a common problem. You can feel the difference with your hand. Using cheap hoses without a spring will cause a hose to collapse.
Old 08-23-2007, 08:54 PM
wayneo69 wayneo69 is offline
air pocket in colling system
