Old 06-07-2007, 04:01 PM
timssail timssail is offline
96 accord sterring wheel shakes
My Step son bought a 1996 accord 154k. I just had all the rotors replaced and the sterring wheel shakes at 25 MPH but is hard to notice at highway speeds. The mechanic said the tires that where on the front where cupped so he swaped them for the back two. The tires are Michilin Xones and are near the end of their life. Any thoughts on this?
Old 06-08-2007, 04:53 AM
jeffcoslacker's Avatar
jeffcoslacker jeffcoslacker is offline
Lactose the Intolerant
Re: 96 accord sterring wheel shakes
If it began after the rotors were replaced, the rotors are not running true for some reason (rust between rotor and hub flange usually) and are causing the wheel to be similarly wobbling slightly...which you feel at low speed, but not so much at higher...
If it was there before, check for broken belt/bead cord in a tire, bent rim, bent stub axle on rear, etc...
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
Old 06-08-2007, 08:34 AM
The wobble has been there before and after the new rotors. Also the back tires where moved to the front because of being cupped and noisy. I drove the car on a dirt road and the wheel did not wobble. when i drove the car with the cupped tires on the front the wheel was a little less active. What is the stub axle? and where is it. I am new to the Honda world. thanks for the reply.
Old 06-09-2007, 06:50 AM
Rear axles are just little short assemblies now on FWD cars...
It really sounds to me like you just have a tire with a belt slip...have someone drive slowly away from you as you watch the car, you'll probably see it swaying slightly...then usually you can spot the tire that's "squirming"...
...empty gun rack.
Old 07-19-2007, 08:34 AM
Problem solved, it was bad tires and the rotors needed to be replace too.
