Old 06-07-2007, 03:24 PM
hawk362's Avatar
hawk362 hawk362 is offline
SL to VR4 Turbo Conversion is it smart.
This is the offer for my car everyone please let me know what you think for $1,200, it is the 9b turbos out of a vr4 all parts listed below are stock, everything has 160K miles on it. How practical is this conversion with a stock automatic transmission, safe?
Intake Manifold
EGR Valve w/ equipment
Coolant Housing/Neck
Y-Pipe
BOV
Airbox w/ filter
Intake plumbing
Intercooler piping
Intercoolers w/ intake ducts
Turbos
Exhaust Manifolds
O2 Housings w/ sensors
Downpipe w/ front pre-cat and main cat
Oil Cooler w/ lines
Oil feed/return lines
Water feed/return lines
Fuel injectors w/ inj. Resistor pack
Fuel pressure regulator
Vacuum lines
Oil return “joint” on engine block
Fuel pump w/ housing
ECU
Oil pan
Engine wiring harness
Misc. clamps, nuts, bolts, gaskets
Old 06-07-2007, 04:15 PM
hawk362's Avatar
Re: SL to VR4 Turbo Conversion is it smart.
Basically what I am asking is, is it worth it to buy this kit for my car with my atx transmission.
Old 06-07-2007, 05:57 PM
Morphius289's Avatar
Morphius289 Morphius289 is offline
160K? You'd be better off just buying a VR4.
Black 1997 3000GT
Originally Posted by Igovert500
[01:05] Igovert500: scrwe his method
[01:05] Igovert500: too much crap
[01:06] Igovert500: i just jam a garden hose in there
[01:06] Igovert500: and put it on high flow
[01:06] Igovert500: go the opposite direction too
[01:06] Igovert500: so it clears out more shit
18 and out of debt - member #1
Old 06-08-2007, 03:31 AM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
morph, no offense, but if i had a dime for every time someone said "just by a VR4 instead," i'd be one fucking rich man.
for the love of god, why does everybody just cop-out and always take the easy route. can you find a VR4 for $1200 that is running as good as his SL with 160k miles on it? NO. and how much more reliable is a SL/Base than a VR4? no transfer case, no crappy grinding Getrash trannies, no VCU to fry, etc. etc. etc.
hawk, to be honest, 1200 is a decent deal for all the TT conversion parts. plus you get a TT ecu. but keep in mind, you'll still need parts like a boost controller ($20-$300), AFC ($100-$250), datalogger ($35-$75). also, with a turbo FWD setup, you will always have traction problems. so if you plan on launching your car, then forget about it. but from a roll on the highway, a FWD TT car will own a stock VR4.
as for you concern regarding the compatibility of a TT setup with an ATX, several people have done it and love it. did you know that with an ATX you can build boost right off the line? brake boosting? there are a bunch of fun tricks you can exploit with an ATX that those MTX guys don't have. actually, Hotshot8792, a member here on AF, has done a TT conversion on his ATX. so you can search his posts or even PM him for details.
don't be discouraged by one or many people telling you to "just buy a VR4." if it was that easy, 1) they would have done it already or 2) are too scared to get dirty and do a TT conversion themselves.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 06-08-2007, 09:03 AM
hawk362's Avatar
Thank you for your honest answer, that really helps, yeah im purchasing the apexi neo safc, and im not sure which boost controller or data logger im gonna get, but thats all way up the road after the turbo is put in. I am just worried my atx transmission will go bad i have 80K miles on my car all together, so im hoping it will be able to stand at least 8psi.
Old 06-08-2007, 01:09 PM
Hotshot8792 Hotshot8792 is offline
if you beef up your tranny, you'll be fine. Basically, just start off with the simple stuff which is the tranny cooler and a shift kit.
Daily Driver: 2004 Jeep Grand Cherokee Special Edition
1994 Mitsubishi 3000GT SL-TT Automatic - Black
3.05 L Arias Forged Pistons, Pauter Forged Rods, DR Stage 3 heads, 3SX TD05 kit w/ E16G's, CX Racing FMIC, 550cc injectors, Walbro 255lph pump, + supporting mods
1994 Mitsubishi 3000GT VR-4 - Black
Intake & Boost Controller so far
2006 Sea-Doo RXP Supercharged, Updraded SC, IC + supporting mods
Old 06-12-2007, 04:07 PM
new2mitsu new2mitsu is offline
i don't kno tho. 1,200 bux for a turbo kit that already has 160k miles on it?
Old 06-18-2007, 08:15 AM
Zeiss's Avatar
Zeiss Zeiss is offline
you can/should be able to get newer parts for less than 1200. It may take a few months to find it but 1200 for parts with 160k is quite a bit imo. If anything buy some of the parts seperatly from different people. You probably dont want turbos with that much mileage. I went the safe route and just bought new ones.
Is it smart? Depends on what you want for your car. Is it fun? Hell yes
Bye V8...
Old 06-18-2007, 10:27 AM
Linebckr49's Avatar
Hawk---> in case you didn't know, Zeiss has done the TT conversion to his car, and its a freaking beast. do a search for threads by him to find out more info.
93 3000GT base
Old 07-16-2007, 11:23 PM
granny_shifter's Avatar
granny_shifter granny_shifter is offline
if i were you i would do a little more research. if you visit 3sx.com you can see what upgraded parts you can get. for sure i know they have a metal y pipe, i hear with big boost applications the stock pops off. there are many things you could probably and most likely should upgrade for age and reliabilities sake. if i were you i would myself buy the parts new.
i understand financial holdbacks and all. i'm 17 with a medium income. but i'm also the type of person who decideds to do something and goes all out. your car will see a longer future with higher quality. life is about choices.
to make a long story short 1200 doesn't sound TOO bad.....
i fix things that aren't broken
Old 07-16-2007, 11:54 PM
Linebckr49's Avatar
granny shifter, this thread is a month old. do you work for 3SX? did you also know that IPSmotorsports.net, dynamicracing.com also carry many products for our cars and sell them for a fraction of the price 3SX does! yes, quality plays a factor, but knowledge and experience are far superior.
93 3000GT base
Old 07-17-2007, 08:32 PM
liquidPunk's Avatar
liquidPunk liquidPunk is offline
Send a message via AIM to liquidPunk
Thank Allah you said something Linebckr!
1992 Mitsu 3000gt sl 5sp
- High flow filter - Pioneer head, dual 10's - H4 headlight conversion
- Throttle Body Spacer - The "For God's sake stop that infernal buzzing" mod
- LED "Snake Eyes" - Lightweight Crank Pulley
-More to come-
Your 3000GT is the 5095th out of 6964 . Only 41exactly identical
Bloody Knuckles from Changing Fuel Filter Crew Member #1
