Old 06-07-2007, 03:15 PM
stealth702 stealth702 is offline
air intake problem .need help pliz?
hey i jus bought a short ram intake for my dodge stealth non turbo,n it was ok but when i hook up my intake sensor plug ma engine starts to stall n smtimes stops so i have to drive without da sensor pluged in ..can u guys help me ..thank you
Old 06-07-2007, 05:41 PM
AutostradaVR4 AutostradaVR4 is offline
Re: air intake problem .need help pliz?
sounds like you broke the MAS...did you drop it or anything when you had it out? they are very delicate. take it back off and look into it. theres a little resistor lookin thing suspended on a wire, see if the wires are broken or anything.
Formerly BlinkRA182
--VR-4-- --09 Lancer RALLIART-- --Me--
Old 06-07-2007, 05:46 PM
91STT 91STT is offline
3SNJ Pres
sounds like a vacuum leak
1991 Stealth R/T TT
It looks stock, so it must be.
Old 06-07-2007, 07:10 PM
ok ima take a look at it, n will let ya guys know thankx
Old 06-08-2007, 04:38 AM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
i agree.
steatlh702--> was there a vacuum hose you connected to your short ram intake?
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 06-08-2007, 03:18 PM
vaccum hose?i did connect a hose tht went from da intake to da manifold rite next to da throttle body...but tht hose is on every intake system...could there be a leek on it?i checked it out but n put a new hose .
now i jus drive it without da sensor but ma check engine light is now on always
Old 06-08-2007, 03:19 PM
do u think without da sensor pluged in ma car would give me problems n stuff,?wat is the main purpose of da sensor ?doe sit do better gas milage
Old 06-08-2007, 04:45 PM
3SNJ Pres
With the MAF unplugged you are in limp mode. The ECU is regulating your injector duty cycle without regard to the amount of air you are taking in. It is using the TPS to "guess" at the amount of fuel you need; usually on the rich side. It will waste more fuel but you will also lose performance. See if anyone from this board that lives close to you, maybe he can lend a hand to narrow down what can be wrong.
1991 Stealth R/T TT
Old 06-08-2007, 05:49 PM
ok i will get smone to take a look at it , thank you
