Old 06-06-2007, 10:10 PM
70camaro 70camaro is offline
OBD-1 sensor readings
I have heard you can get realtime sensor readings through the ALDL port on OBD-1 equipped vehicals... How does one do this?
Old 06-06-2007, 11:18 PM
2000CAYukon 2000CAYukon is offline
Re: OBD-1 sensor readings
I bought a cable from http://www.akmcables.com/ (or you can make your own) and then download WinALDL from http://winaldl.joby.se/ on to my laptop.
It only works on the ECMs that are listed on the website. I use in my 90 GMC K1500.
//2000CAYukon
Old 06-15-2007, 10:47 AM
Thanks much, that's excatly what I was looking for!
Old 06-15-2007, 11:05 AM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
I have WinALDL installed on my laptop and I made my own cable following the instructions on the WinALDL site.
Since my car is carbureted, the signal doesn't come from Pin E on the ALDL (there's nothing hooked to Pin E), it comes from Pin D.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
