Go Back   Automotive Forums Car Chat > Lincoln > Town Car
Old 06-06-2007, 09:37 PM
Dmartin_1 Dmartin_1 is offline
Question trans. problem 1988 TOWN CAR Help please
Hi I have a 1988 town car 5.0 When I'm in overdrive and hit the smallest hill seems not to down shift, You have to shift it by manual. Yes the Linkage is hooked up.It shifts fine when it up shifts . Any suggestions? Thanks Danny its an AOD trans.
Old 06-06-2007, 09:50 PM
junk yard doggie's Avatar
junk yard doggie junk yard doggie is offline
Re: trans. problem 1988 TOWN CAR Help please
I believe your car has the vacuum. modulator. Bolts onto the back of the trans and has a vac. line connected to it. The vac line runs from the intake manifold to the back of the trans. Its usually a metal line with rubber hoses on each end. Could be a bad modulator or you line has come loose or the rubber hose is split on the ends.
Mike
Old 06-06-2007, 10:05 PM
Mike
I didn't thank it did but Ill check it.Its got a kick down linkage hooked to the trottle body.It shifts perfect all the time just won't down shift from over drive.But it will manually tho.Its an AOD tran.
Old 06-07-2007, 02:48 PM
This is the problem and how to adjust it .
http://www.lincolnsonline.com/tech/00138.html
Also very helpful money saver
http://www.lincolnsonline.com/tech/00052.html
Old 06-07-2007, 03:23 PM
Question Re: trans. problem 1988 TOWN CAR Help please
Kinda acts like it jumper time
Old 06-12-2007, 12:27 PM
Wink Re: trans. problem 1988 TOWN CAR Help please
Hi it all come down to a pugged exhaust causing loss of power. fixed the problem $170.00 .If the motor don't run right the transmission won't shift right.I'm just glad I found the problem before I burned the transmission out.Thanks for the help. Danny
