Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon > 1st Gen 95-99
Old 06-06-2007, 09:21 PM
ikeyballz ikeyballz is offline
Send a message via AIM to ikeyballz
AC condensor..
my AC isnt dripping the water onto the ground.. its falling into the passenger seat floor
anyone had this problem? what is it? a plugged hose?
Car:
1997 M6 SS Camaro [ white ]
285's in the back
all else = STOCK.
Old 06-07-2007, 10:45 AM
denisond3 denisond3 is offline
Re: AC condensor..
It could be a plugged drain hose, the drain hose pulled off the evaporator housing under the dash, or the evaporator housing having a seam that opened up. Other than trying to find the drain hose were it emerges into the engine compartment, looking under the dashboard might be required. Will probably be a tough spot to observe and work on; you might try removing the glove box and going in through that space. Sometimes I have removed the passenger seat to work on heater/ac. items on my cars.
Old 06-08-2007, 01:35 PM
das2123 das2123 is offline
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
Re: AC condensor..
Remove the cowl cover and clean it out, drill a couple of holes so the water can drain better if its clogged.
2003 Dodge SRT-4
Old 06-12-2007, 05:11 AM
Re: AC condensor..
oh.. lol, thanks i checked thsi after i fixed it.. thanks:P i sorta did what you said
Car:
285's in the back
all else = STOCK.
