Go Back   Automotive Forums Car Chat > Chevrolet > Chevrolet Classics
Old 06-06-2007, 05:26 PM
rainbarl rainbarl is offline
1976 caprice won't start
Got my dad's '76 caprice (47,000 miles). It won't start. Won"t fire. Tried distri. cap, plugs, gas filter, new gas tank HELPPPP
Old 06-06-2007, 07:20 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: 1976 caprice won't start
How does it sound when it's turning over? Normal, or wierd? Take the distributor cap off, and have someone crank the engine. Is the rotor turning? If not, be prepared to get greasy replacing the timing chain and sprockets.
Loosen the fuel line nut at the carb and have someone crank the engine for about 2 seconds. Have a fire extinguisher nearby. Does gasoline leak/spray out?
Turn the ignition to ON and check for the presence of 12.6 volts at the distributor power terminal (the one marked BAT - usually a heavy red or pink wire). The HEI system uses full battery voltage - it does not make use of a ballast resistor. Check that the 3-wire plug from the distributor is secure in the cap (behind the terminals marked BAT and TACH). Use a special spark plug gap tool (plugs into the wire in place of a spark plug) to check for spark. Don't use a screwdriver or leave the wire disconnected as this can cause coil failure. If you have no spark, but you have 12.6 volts to the BAT terminal on the distributor, then possible failure points are the module, the pickup/reluctor assembly and the coil.
Verify that all vacuum lines are hooked up and in good condition, with no cracks or other deterioration. Verify the routing against the schematic under the hood.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
