Old 06-06-2007, 03:19 PM
c_perrymsu c_perrymsu is offline
Camshaft Position Sensor '98 3100
Can somebody tell me where the camshaft position sensor is on a '98 GP SE w/ 3100 engine? Thanks.
Old 06-06-2007, 04:04 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: Camshaft Position Sensor '98 3100
For a 3100 VIN "M" engine the CMP sensor is located on the front of the engine block at the top after the timing cover which will be in the area of the camshaft drive spocket. You'll need to remove the serpentine drive belt and power steering pump to access/replace it. There is a single bolt that secures it. Bolt torque is 8 ft-lbs. Inspect and/or replace the o-ring seal if you decide to replace the CMP.
Timeslip 08/12/06
AF Community Guidelines
Old 06-06-2007, 08:21 PM
Sweet, thanks.
